Saltar al contenido principal
A1708 / EMC 2978 — Lanzada en Octubre 2016, este MacBook Pro de nivel básico retiene sus teclas tradicionales de función (en lugar del OLED Touch Bar). La versión con teclas de función incluye un Intel Core i5 y dos puertos Thunderbolt 3.
Preguntas 215 Ver todo
Can the SSD be switched out?
Can the SSD be switched out and upgraded ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
Agregar un comentario
7 Respuestas
Respuesta Más Útil
Looks like the entry level 13" isn't soldered
OWC noted the following points in its teardown.
– Bottom was more difficult to remove than previous generations, but it was not glued.
– Speaker module needs to be removed to pull SSD back.
– SSD had very strong tape covering the interface port.
– Laptop automatically turns on when you open it regardless of pressing power button.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
If you review the OWC vid you'll also see the SSD module is very different from the older systems and it looks like a custom part! So, even if its removable, it will be a while before we see a 3rd party option.
- de
@danj Yes I saw that! Hopefully the wait isn't as long as it was for the Retina models!
- de
http://blog.macsales.com/38440-ssd-in-la...
Puntuación 1
Yes, Please look at
Puntuación 1
Yes. But so far no one has made an SSD that is compatible with this model, the first few will begin to pop-up within the next few months.
Puntuación 1
Yes is it removable.
Update (10/31/2016)
Puntuación 0
2 comentarios:
Do you have a back up link on this?
- de
I would like to know where you got this information. Nothing on the internet says Soldered, but I wouldn't put it past them
- de
Anyone here who knows the pinout of the new SSD?
Puntuación 0
Adapter for MacBook Pro 13” 2016/2017 nTB
https://www.globalmac.cl/Adaptador-SSD-M...
(Chile)
Puntuación 0
Añadir tu respuesta
benkuza estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 7,920
