Bluetooth Speaker not charging.
Hi,
my Bluetooth speaker stopped charging one day. As far as I know it did not suffer any physical damage or anything of sorts. I used to carry it with me sometimes but usually in a bag.
It still has some juice in it because it turns on but after a few seconds turns itself of with not enough battery. LED indicator doesn't even lit up when I connect it to USB cable.
I already opened the device and well everything looks in place. So, if anyone have any idea of what might be the faulty part I would be grateful for suggestions.
It's actually pretty cheap but I am kinda curious what went wrong.
Thank you.
Es esta una buena pregunta?
9 comentarios
For anyone that might still have the problem, I have something that might work.
I tried this but it didn't work. What I did afterwards was taking apart the entire speaker and reconnecting all the plugs. After that I tested to see if it charged but it didn't. I then figured out there is a reset option. Hold the battery indicator button until it says something along the lines of "factory reset" if that is in chinese than google translate will do the job.
After this it still didn't charge so I gave up and let it sit on my desk for a while. When I plugged it in a couple of days later it charged again!
Try my method without taking it apart first and if it doesn't work than try taking it apart at your own risk if you want to.
Hope this helps!
- de SaneBiker
Have used my Q3 Bluetooth for long and I charged it it’s charged and to on it, it does not on what can cause that and what’s the solution to it
- de Badejo Atinuke
I just resolved my problem with my Doss Soundbox Pro not charging. When it is charging but plugged in, there is a red light inside the reset port that stays on red. When fully charged, the light goes out.
In the not charging scenario, that same red light flashes or blinks. And no amount of time will see it start charging, even after a reset.
So, I visited Youtube and there were only two videos on this subject, both fairly short.
The first showed a very simple way of getting lint and any other foreign matter out of the charging port, safely.
The second was easier. He stated that simply changing the cord solved his problem, showing the use of the cord in question and then replacing it with one that got the speaker charging as it should. Easy peasy.
Finally, consider Occam's Razor, (the right answer is usually the simplest), before tearing your bluetooth speakers apart.
- de MICHELLE HOGAN
Hi my sd-306 karaoke speaker is not charging. The lights is still red as its not turning green. Pls help.
- de anntasyawazyn
POSSIBLE SOLUTION
My W-King speaker worked great for a couple months. Then one day while using it, it shut off. I had used it extensively for two days without recharging so I figured the battery was drained.
I plugged it in, but it wasn't charging. After several attempts and frustration I discovered the combination.
First I plugged in a USBC into a wall adapter and the other USBC terminal into the speaker. It didn't work.
I dug out the cable that came with the speaker and plugged the standard USB terminal into the speaker and the USBC terminal into the wall adapter. No bueno.
I tried to charge my phone (USBC) and it worked with the standard USB end in a USB wall adapter and USBC piece in my phone.
With this combo, the speaker charged
*Wall adapter-USB-USBC-W King speaker*
Hope this helps someone.
- de JD Parris
Mostrar 4 comentarios más
