Saltar al contenido principal
La Nikon 1 AW 1 es una cámara a prueba de agua fabricada en 2013. Esta cámara es compatible con Wi-Fi y graba en 1080p con una lente de 14.2 MP.
Preguntas 7 Ver todo
Why did it stop working after a swim in shallow water?
I went swimming in my 6 ft pool and after taking a few pictures, it stopped working all of a sudden. It says that it's waterproof up to 15 meters so this shouldn't have been a problem for it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Did you make sure that your lens was secured tightly to your camera? Is it not turning on at all? I would refer to the troubleshooting page to see some quick solutions that might solve your problem. Apparently this is a common problem with this specific camera, however, if the camera is not turning on at all, I placed it in a bag of rice for a few days, then gently blow dried the camera and it turned back on! Hopefully this helps and I wasn't entirely lucky. Good luck bro!
Fue útil esta respuesta?
Puntuación 0
The O-rings need to greased (first cleaned), before each use, like those around the battery door, and the lens mount, or the risk for water ingress is huge!
Puntuación 0
Añadir tu respuesta
Daniel Heshmaty estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 229
