Saltar al contenido principal
Amana Refrigerators are manufactured by Whirlpool Corp group, in Amana Iowa.
Preguntas 24 Ver todo
Amana Refrigerator Water indicator light in front panel won't come on
I have an Amana side by side refrigerator model
ASD2575BRW01.
The display panel has lights on the outside front panel that indicate light on, light off, crushed, cube, water, lock on, lock off.
All of the lights work except the one for "water".
All selections work; I just don't have an indicator light for the water.
I don't know how to repair it.
I don't even know how to remove the panel if I can repair it.
Es esta una buena pregunta?
Puntuación 1
1 comentario
I appreciate the speedy assistance with this problem.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
George, The refrigerator dispenser control board is normally replaced as an assembly, the bulbs/diode are soldered into the board assy.
If all is function well on your fridge except for the one faulty light, the board could be removed and the bulb/diode replaced by a skilled computer repair shop, if they were willing to do or you could just live with light not functioning, or change the board.
Check the attached links,instruction and guides on how to may not be your exact model but give general idea of what to do. Good luck.
https://www.youtube.com/watch?v=42VU2Mbr...
http://www.repairclinic.com/PartDetail/A...
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Thank you for your help. I'm still not sure exactly how to remove the panel for this particular refrigerator. It is differs from the ones I have seen on YouTube. Considering the cost of replacing the panel, I will probably just live with it for the time being.
Again, thank you for your help! Have a blessed day!
- de
George, I have one more link for you to check out with a diagram of the control panel, in the pic. it shows no screws, so it must just snap in with pressure clips molded onto the trim of panel. It is parts diagram #13 of the link, have a good day.
http://www.searspartsdirect.com/model-nu...
- de
I figured out how to remove the panel.
Insert small flat tipped screwdriver into slots in bottom corners.
Panel will then slide down and out so you can unplug electrical connection.
Puntuación 1
Añadir tu respuesta
George VanLuven estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 2,186
