27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
Preguntas 74 Ver todo
When turned off the fans keeps spinning. Is it normal?
The fans are normally very quiet but when i turn off the computer the fans of the thunderbolt display first starts spinning very fast and after 5 seconds keeps spinning not so fast but keeps running until I power on my computer again. Is it normal?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
ya it normal.
por
Like Colonel Hogan answered is not normal, and apparently it is a common problem
por
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
3 Respuestas
Respuesta Más Útil
Hi,
have you latest Thunderbolt Firmware installed ? Check Mac Software updates. There was an update adressing fan related issues.
Update (01.10.2016)
So, now i found this about the problem.
Seems to be an apple known problem.
https://discussions.apple.com/message/16...
Fue útil esta respuesta?
Calificación 1
Hi Colonel Hogan,
Thanks in advance for you answer.
Yes, i've already checked the updates. It is the last version of the firmware (26.2)
It is not normal right? For the thunderbolt display's fans starts when turned off.
Calificación 0
Comentarios:
Have you attached external devices to the TBD ?
por
No, all the ports in the TBD are unused.
por
I realize I'm incredibly late to the party here, but if you've got your MacBook charging even when it's off, the fans will cool the power adapter.
Calificación -1
Comentarios:
Sorry dude, Its a Thunderbolt display not a macbook that is having the problem.
por
yes, that's abundantly clear. in case you're unfamiliar with thunderbolt displays, they have built-in MacBook chargers. when said built-in MacBook charger is plugged into my Mac and charging, it creates heat. the fans inside my Thunderbolt Display turn on to keep the AC/DC conversion circuitry cool, even though the display itself is powered off.
thanks for giving ME a demerit for YOU not knowing what I'm talking about.
por
Añadir tu respuesta
Kojiro Nagai estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 100
