This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Preguntas 47 Ver todo
I need to replace the glass
I have a LG v10 and I need to replace the glass
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
The glass screen on this phone is repairable, but difficult. You can get it professionally repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
por
Agregar un comentario
2 Respuestas
Solución Elegida
Here is a link that should help. Tap or click on the blue link. Good luck.
https://m.youtube.com/watch?v=H5VDlpRFBK...
Fue útil esta respuesta?
Calificación 2
Comentarios:
The glass is difficult to repair on this phone, but repairable. You can get it repaired here: http://www.ebay.com/itm/LG-V10-Cracked-B...
por
Respuesta Más Útil
They sell just the glass online, but I would highly suggest you avoid that. The entire assembly is glued together and there are some very delicate components between the different layers. I was unable to replace just the glass and ended up destroying the whole LCD screen in the process. Your best bet is to buy the whole display digitizer touch screen assembly. They currently run about $150, but most of the videos online about replacing them include the entire assembly, including the one above.
Calificación 3
Comentarios:
I dropped my phone and the screen had spider web cracks. Then I just took off the outter screen. It was a pain in the butt but it still works as it did before. Im guessing the outter screen isnt the digitizer?
por
What did you do to remove the outer screen? Is your phone the V10?
por
I wish i knew that before i attempted it] not just the v10 but also on the LG stylo 2 plus.dead
por
Añadir tu respuesta
Luis Milla estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 26
Últimos 30 Días: 124
Todo El Tiempo: 5,557
