Saltar al contenido principal
Do you need replacement brushes for the B&D DR500 drill?
I don't know if this a proper use of this forum. If not please forgive me.
My B&D DR500 1/2" reversible drill recently started having intermittent power outages and eventually would not power on at all. I found that one of the two motor brushes was worn down to nearly nothing and made poor contact. The other brush was only a bit longer. I found that replacement brushes were B&D part number 385733-01; lots of places had that part listed, all as "no longer available." I measured the residual brushes as 15/64" square and about 7/16" long. I found a host of online sellers (Ebay) selling 15/64" square brushes that were 1/2" to 3/4" long with attached leads, so I ordered some. My drill uses only the graphite blocks with no leads, so I (gently) sawed off the leads to get the proper length and put them in the drill motor. The drill now works fine. This was a much better solution than throwing out a perfectly good drill due to lack of a couple of tiny pieces of graphite. The brushes online are so cheap (~75 cents a pair) that you can buy several in case you mess up the saw cut. I am posting this in the hope that anyone else needing these does not have to waste as much time as I did looking for new brushes and does not have to discard an otherwise fine drill. This probably works for many more Black & Decker drills, etc that use this part number.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Good start for a guide. Did you take any photos?
- de
I didn't think of taking photos. I still have the drill and I am getting pretty good at taking it apart, so I'll try to post some. You mention a guide. I could pretty easily make a pdf with description & photos of the whole process (I wrote lots of instructions in my career). Would such a document be useful and is there any good place to post one to make it readily available? Although I am working on this one motor, the concept & process could probably apply to many more. However, with the size of the internet and the number of handy folks out there, I expect such a guide should already exist and the only real value of my post is to correlate model/part numbers with suitable replacements.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Go here to create a guide:
https://www.ifixit.com/Guide/new
It will walk you through the steps.
Fue útil esta respuesta?
Puntuación 1
I made a guide a while back.
Black n Decker DR500 Drill Motor Brushes Replacement
Puntuación 0
Añadir tu respuesta
Doug Ackerman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 514
