Saltar al contenido principal
Aquí encontrará varias guías de reparación diferentes para el Dell Chromebook 11 (CB1C13): modelos de 2 GB y 4 GB
Preguntas 11 Ver todo
bypass enterprise enrollment on the Dell Chromebook 11 CB1C13
Ive tried to get into developer mode but I have not succeeded because it says that it has been disabled by the enterprise enrollment. Please tell me how to bypass the enterprise enrollment.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
1 comentario:
l have the same problem, but l have two of the same make and model l was able to get one working and powerwash that one but have trouble with other, cant get into admid dev mode, if anyone can help or comments, advice is much apreciated, thanks
- de
Agregar un comentario
4 Respuestas
You cannot bypass enterprise enrollment without access to the admin console under which device was enrolled under. https://support.google.com/chrome/a/answ...
Thus, you cannot enter developer mode without your administrators permission.
Fue útil esta respuesta?
Puntuación 0
Yes it won't let me Every time I try it keeps sending me to the screen Where it says Admin is blocked
Puntuación 0
what if l tried to wipe the memory and try a fresh install with different OS on a usb thumb drive , could l get into or have access to dev mode through a way like that?
Puntuación 0
After a powerwash, run through the prompts that are presented in regular usage, set up wifi, and allow the machine connect to wifi and contact google. If the device has been legitimately sold off, the enrollment should drop, and regular login and guest mode should show up in the bottom left corner. If this works, you can then set it to developer mode.
If not, you can wait, try again in a few months, but it is likely that the machine was marked stolen at some point.
Puntuación 0
Añadir tu respuesta
Joseph JS8517 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 3,754
