Daisy Model 10 Carbine 400 shot BB repeating air rifle. Maximum velocity: 350 FPS. Maximum shooting distance: 195 yards. Lever cocking action. .177 cal. BBs. Part No. 300664-000
Preguntas 6 Ver todo
BB gun will $!^& but not fire,doesn't seem to compress spring
Daisy Red Ryder B.B gun model 1938B
so my son,daughter and i were enjoy some pinking when my daughter says the bb gun wont fire. put it on safe and took if from her, I manually cocked the lever but if felt like there was no resistance, took gun off safe aimed and attempted to fire, nothing happened, tried the safety a few times to ensure it wasn't stuck.. that isn't the problem..
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
apparently there is some sort of language filter here, I will assume you guys/gals know what I am trying to say about the condition of the gun.
por
It won't pump up ;-)
por
sure, there is another word but..
por
Agregar un comentario
2 Respuestas
Solución Elegida
bpjefferson365 and @mayer, my thought is more related to the plunger and the lever not connecting. If the lever does not connect with the plunger then there will be no resistance. Even if the spring would be broken, it would still have some resistance since it can not move anywhere. See if this diagram will help a bit. Here is a really good tutorial, even so the model is different. It should still apply to your Daisy as well.
Fue útil esta respuesta?
Calificación 3
Comentarios:
It may be c*cked now.
por
Nah, the mechanism is not working for that
por
Try checking out the firing mechanism : Daisy Model 10 Carbine Firing Mechanism Replacement
Calificación 1
Añadir tu respuesta
bpjefferson365 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 17
Últimos 7 Días: 171
Últimos 30 Días: 787
Todo El Tiempo: 10,945
