Hi,
Does it happen when the car is stationary? Does it happen with the engine off? Do you have any problems with other circuits in the car that are fed off the accessories power e.g. cigarette lighter, power windows etc?
If it only happens to the radio with the engine on and more when you are driving it sounds like there is a loose connection or dry soldered joint in the power supply for the radio or in the radio.
You might have to connect a test lamp or DMM (digital Multimeter -Voltmeter function) to the power feed where it goes into the radio itself (or as close to the radio as you can get) to prove whether the problem is with the power into the radio or it is in the radio itself, i.e. either the power is on all the time at the radio power input point or it comes and goes.
If it is with the feed to the radio you need to check the wiring path from the radio fuse in the fuse block right through to the radio itself.
It may be for instance a loose connection at the rear of the fuse in the fuse block.
What type of fuse is installed? If it is a knife blade type check that the female connection point in the fuse block looks OK and that it has enough tension on the fuse. If it is a glass type fuse, again is it tight in the fuse holder, have you tried a different fuse of the same rating?
26 comentarios
i have this same problem but its with a AVH-X1700S
- de javedramsundar
I have the same Problem with AVH1300NEX. Powers Off, then back on and remains fine ,Until I restart the engine. Happens every time, and the exact same Time frame after engine start. Pioneer said Might be a Firmware Issue.. Also had an Issue getting the steering wheel controls to work. ( Had to re flash the Metra Adapter.
- de Randy Cooke
I have the same problem on AVH-X2750BT . I tryed checking all connentions including all ribbon wires inside the unit i also did a firmware update ver 8.53 but none that worked .Is there a software update i can try ?
- de Huston
Hi,
I'm having a similar issues I had a pioneer radio the Bluetooth setting vanished, the radio was replaced with another pioneer than a day later would switch off automatically wouldn't switch back on until by itself approximately 20 minutes later but then would stay off again. Had this changed to a Sony radio now doing exactly the same.
- de j.adio
I have a somewhat similar question about my pioneer bluetooth car stereo. My audio shuts on and off going down the road. It makes a like scratching noise then it'll shut off then turn back on. Ive tried fuses,pulling the radio out and checking the connections, checking speaker connections,ect but it still continues to do the same thing. I have no ideas anymore.
- de Jake Ervin
Mostrar 21 comentarios más
