The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Preguntas 21 Ver todo
F150 2014 Iwe4x4 grinding and rubbing sound in 2wd and In 4wd
I have a 2014 stx 4x4 that keeps having grinding and rubbing sounds coming from the front end. Sometimes it comes when just driving in 2wd the other times when shifting into 4wd. I took it to the dealership 3 times so far. The first time they said they replaced all 3 IWE'S. The sound went away for a week. So I took it back the second time they replaced the front axle and the solenoid for the IWE. They had it for a week this time I picked it up friday and its still making the whinning and grinding sound like its partially engaged. The truck was sold to me certified pre-owned and only has 19,000 mi. Has anyone else had these same problems?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hey James,
I found a forum post that might help. Check This out. Sounds like if you already replaced the solenoid, you may have to replace the IWE. There's a trick in there about driving 4x4 or pulling vacuum lines to have the truck drivable.
Cheers
Fue útil esta respuesta?
Calificación 1
Comentarios:
Thanks I'll check it out
por
Añadir tu respuesta
James Starrett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 24
Últimos 30 Días: 160
Todo El Tiempo: 2,982
