A laptop series by HP. Identifiable by the model number G62-XXX-XX, endings vary depending on options and seller.
Preguntas 20 Ver todo
HP g62 347NR no display on screen
I have a HP G62 347NR that powers on but there is no display on screen
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Connect an external monitor to the laptop and see if there is a display showing on it when you turn on the laptop.
If there is no display showing on the external monitor you most probably have a GPU or motherboard problem.
If there is a display showing on the external monitor, try holding a torch at an angle close the the laptop screen and see if you can detect the Windows desktop being displayed.
If you can see the Windows desktop this way then you most probably have a backlighting problem.
If you cannot see the Windows desktop this way then you either have a faulty video cable between the motherboard and the screen, a faulty video cable connection on the motherboard or the LCD screen or a faulty LCD screen.
Fue útil esta respuesta?
Calificación 4
Añadir tu respuesta
SINCLAIR ROBERTS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 8
Últimos 30 Días: 36
Todo El Tiempo: 816
