Can I upgrade the drive?
Just bought this: Lenovo Yoga 300-11IBR 80M1 - 11.6 as my son's first laptop. I thought it was a bargain and found out it was because the system drive is a 32gb one. With Windows 10 Home on it that actually leaves just over 8gb for apps and files!
I thought it was an msata drive and that I just could hop on to Amazon and buy a bigger one. I then found the full spec online, and it is actually an eMMC drive, embedded in the motherboard!
My question is the following: has anyone opened that laptop? will I found a msata slot or a sata connector in it - or am I stuck with this ridiculously small storage?
Cheers
Es esta una buena pregunta?
4 comentarios
Thanks for the answer. The laptop is a disappointment, I bought it in a rush in time for a birthday. As soon as a few programs are installed and the Windows updates start kicking up, the laptop will be unusable... They should not be allowed to sell laptops with such configuration.
- de Fred Gaine
If you have a money-back option, i suggest you utilize it and go for a Yoga-300 model 80M100TPHV. This has a 500g mechanical HDD which you can replace with an SSD and buy a cheap USB enclosure for the HDD to use it as external storage. I'm not sure if the 11IBR model even has a SATA/M.2/mPCI-e port available (or it has been removed from the mainboard). Even if a port is available, it might not recognize an expansion SSD/HDD. A good starting point is to look at the UEFI setup program: if you can alter the boot device options (even if only the eMMC is present), you may be able to get it to work with 2 drives, but there is no guarantee for it to work and even flashing the UEFI with a possibly cooked version may be involved (say goodbye to warranty)
- de datawraith236
The SATA connector not enough.
- de Dawid Łukasiewicz
Can someone also help me i have sata connector and hdd 2.5 but when i try to insert it the main 32gb drive wasnt able to detect ang it will detect the new hardrive .
Any ways that i can copy its original os to the hard drive that i connected .
Thanks
- de dingson_20
