Change original PM ic can restore the iPhone?
Hi! My iPhone won't turn on n charge. I can connect to the iPhone in DFU mode and iTunes has detected an iPhone in recovery mode. Popup the message You must restore this iPhone before it can be used with iTunes.
I go to other shop they think may be PM ic isn't working they change the IC but iPhone still won't turn on.
Now the problem is after change PM ic i can't connect to the iPhone in DFU mode.
Is Possible after change the original PM ic to other ic can't connect to DFU mode or recovery mode???
Thanks
Es esta una buena pregunta?
recovery mode press power and home button the same time and connect to prog 3u tools and flash
- de rakan
