Saltar al contenido principal
Procesador G5 1.6, 1.8 o 2 GHz
Preguntas 131 Ver todo
Display power inverter pinout or voltage for each of 6 pins needed?
I have a broken LCD on my netbook. The LVDS cable correctly fits in the display for my iMac which was gutted when the logic board caps went bad.
I have tossed the logic board. I still have the display, the power supply and the inverter. I need to know the voltage that each pin on the inverter takes to power the back light on the iMac display directly from the power supply.
The following links may be helpful to someone who speaks French.
http://forum.macbidouille.com/index.php?...
[ http://users.skynet.be/fa835376/pas%20a%...]
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
This is from an iMac G4 is this something that you are looking at?
The inverter has 8 pins in as described below.
Blue = 11.93v
Red = 11.93v
Blk = GND
Blu = GND
N/C
Yel = .2mv
Prpl = 3.262v
Orng= no voltage detected
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Check this out and see if it will help you.http://dremmeljunkie.blogspot.com/2010_0...
Good luck
- de
Also if you have the part number here you can look up the specs
http://www.jkllamps.com/index.cfm?action...
- de
Añadir tu respuesta
Shane Nelson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 6,471
