The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
Preguntas 20 Ver todo
My phone is not turning on.
my phone's battery was down while i was talking through it. suddenly phone switched off . i connected this to charger but it was showing nothing on phone screen. till now it's not charging , not turning on too.please suggest what to do now.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 8
Agregar un comentario
8 Respuestas
Solución Elegida
Thanks. I have fixed it! I pressed volume, home and power button together. It is working now. Thanks again !!
Fue útil esta respuesta?
Calificación 4
Comentarios:
sir it is a battery problem if u change the battery then it will be fixed
por
volume means? + or -
por
Betary ok but no trun
por
I try this but no on
por
I also have a problem my Samsung galaxy j2 does not want to install anything how can this be fixed
por
Mostrar 4 comentarios más
Do you charge the phone for around an hour. If no, try it and see how.
If yes, try to press volume up, home button, power at the same time. This works for my s7 edge that have the same issue with you. If nothing comes on, try to press volume up and power at the same time.
Also try to replace your battery, a dead battery may cause phone not to boot.
Still no response? Maybe your logic board maybe dead. If yes, return your device ASAP before the warranty is void.
Warranty void already? You should run out of luck, you can't fix it anymore. Because normal users can't do it
Calificación 3
Comentarios:
Now i what to do
por
same problem there ....my phon should not open when power on screen has been blinking black light
por
My j2 has also a problem. For example my battery is 73% then my phone will hung and stuck, I have to remove the battery and put it again, then open but after I open, it turns 0%. I bought a new battery but it still the same. I reset my phone but it still happens what's the problem with this.. What should I do?
Calificación 1
scratch keys on battery points. it's carbon problem.
work for me.
Calificación 0
If you have a removable battery then just open the back cover, take out the battery, and reinsert and restart. This solves the problem. Probably there is something wrong with the battery.
Calificación 0
Comentarios:
but its happening frequently
por
My phoan is not format
Calificación 0
do the planetary devastation techniques !!! just try to throw your phone in the 13th floor building and put in your refrigerator in 7-days. then try to roll over under the wheel of 10 wheeler truck. then pray. keep calm .. and sleep about 8-10 hours, then smile very wide.. and everything will be fine after 10 yeaRS,
Calificación 0
Comentarios:
My j2 is just stopped . Suddenly the phone became very hot and after a while it is not responding. What should i do now??
por
My galaxy j200g is not starting when i start them then i only saw samsung galaxy j2 powered by android and he doesn't start
Calificación 0
Añadir tu respuesta
Udita Mandal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 71
Últimos 7 Días: 524
Últimos 30 Días: 2,012
Todo El Tiempo: 23,108
