Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 3950 Ver todo
Can't hear music playing without headphones
My girlfriend's iPhone won't play any music or snapchat video audio unless you have headphones in. What's weird is that the phone says theirs headphones already plugged in but there's nothing plugged in. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
If it thinks there is a headphone jack still inside this means that the headphone jack is clogged, water damaged or just has gone plain faulty.
You can try cleaning the headphone jack first and if that does not work then you will need to replace the charging port dock assembly.
I tried cleaning it for a few clients. All ended up still not solving the issue so I ended up replacing the charging port dock assembly for them.
You can get the part from here:
iPhone 6 Lightning Connector and Headphone Jack
Repair guide:
iPhone 6 Lightning Connector Assembly Replacement
Imagen iPhone 6 Lightning Connector and Headphone Jack
Producto
$24.99
Fue útil esta respuesta?
Calificación 2
Hi,
there can be multiple reasons for this issue,
if the headphone socket was given a rough mechanical stress [Usage of incompatible headphones].
or it might be a software issue [In that case you can try a Factory Reset]. But without a proper diagnosis its hard to figure out..
All the best..
Calificación 1
Hi friend,we think it is the problem of loudspeaker,maybe you can go to repair shop and test it.
Calificación 1
Añadir tu respuesta
Keney Napoleon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 17
Últimos 7 Días: 73
Últimos 30 Días: 357
Todo El Tiempo: 3,120
