Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
Preguntas 356 Ver todo
My wifi and Bluetooth won't turn on
Is the wifi board located on the midframe or is it directly on the board. I have an issue with my S6 with the wifi and Bluetooth not turning on at all. Tried multiple restarts and factory resets I just noticed that I have no sound either so the speaker on the midframe seems to be toast as well. Would you think this is the midframe contacts causing this issue? If so how would I repair this?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Phone still got warranty? Get it replaced. Otherwise the Wi-Fi ic / chip needs to be replaced.
por
has the phone been opened?
por
Agregar un comentario
3 Respuestas
Solución Elegida
The wifi/bluetooth chip is soldered directly to the motherboard. Sounds like the phone has probably experienced a substantial impact at some point, but there could be other causes. If your frame is bent I find it unlikely that the speaker contacts would have lost contact. Either way, your wifi/bt issue will most likely require a board level repair to replace the chip. You want to be very selective about what shop you let attempt this. An inexperienced tech could easily make this bad situation worse. Either way, I cant see it costing less than $125 with around a 10 day turn around time if you can find a reputable repair shop and have to send it off. I would personally contact iPad Rehab in New York and ask if they'll take the repair.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Of course there's always the possibility that some files in the system partition have somehow become corrupted, in which case a factory reset wouldn't help. In that case you'd need to reflash the phone's stock software from a computer using the Odin tool and a tar image of your phone's firmware. But again, this sounds more like hardware to me
por
I have already tried a different rom and re-flashed the stock rom via Odin to no avail. I have also removed the board and checked it over and also cleaned the contacts with iso (99%) alcohol. Im assuming now I have a motherboard issue which is unfortunate because I love the phone and also have the GearVR which is virtually pointless to have with the phone with no wifi/Bluetooth or sound lol
por
Hi
I have the same problem i trots everything that is possible , diffrent firmware, hardreset, flash with Odin and z3x . The problem is in the logicalboard but i dont see which one is the wi-fi ic.
Calificación 1
lenovo a536 didnt had any sound coming from it wether its from video or music files even ring tones. fixed it just by turning the phone of and taking out the battery for couple of minutes and inserting it again and turning the phone on its that simple
Calificación 1
Añadir tu respuesta
Jamie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 19
Últimos 7 Días: 167
Últimos 30 Días: 880
Todo El Tiempo: 27,884
