The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
Preguntas 1458 Ver todo
iPhone screen went black but is on
Hi,
I was using my iphone 5c just a moment ago and was on facebook, then the phone locked up, i couldnt do a thing, then the top quarter of the picture started to do almost like a dissolving thing so that the picture started disappearing, then the screen went blank,
Here's the steps i have taken to resolve this.
Tried turning it off using the power button - Did nothing, screen is still black
Tried holding the power button and home button together - Did nothing, screen is still black
Replaced the screen - Did nothing, screen is still black
Tried plugging it into the computer and doing a reset - Did nothing, screen is still black
However, i can ring the phone and it rings.
So whats the problem? why has my phone randomly died? could it be that the gpu chip has committed suicide?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
You did everything right in terms of troubleshooting. It sounds like the LCD has gone bad. Luckily, this is is a relatively easy fix if you take a look at the iFixit guide. This will also provide the link to the kit you will need in order to do the repair if you do not have the tools.
Just so you are aware, the part does not include the home button or the front camera assembly. These will need to be transferred to the new screen. Be sure to use heat to remove the button and camera because simply pulling them off can tear the cables.
Home Button Guide
Front Camera Guide
Imagen iPhone 5c Front Panel
Guía
iPhone 5c Front Panel Replacement
Dificultad:
Moderar
30 minutes - 1 hour
Imagen iPhone 5c Home Button
Guía
iPhone 5c Home Button Replacement
Dificultad:
Moderar
1 - 2 hours
Imagen iPhone 5c Front-Facing Camera and Sensor Cable
Guía
iPhone 5c Front-Facing Camera and Sensor Cable Replacement
Dificultad:
Moderar
40 minutes - 1 hour
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
h1cks2002 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 162
