Stick vac not charging
Hi, I was using my beloved Ergorapido (20 months old, working well to this point), battery was probably getting quite low, when all of a sudden it cut out, but in a stranger way than usually when the battery runs out. The suction usually drops off for a couple of minutes before the whole thing cuts out, but there was still fairly good suction at that point - motor still quite loud.
I put it on to charge but nothing is happening. When I place the whole stick vac on the charger the charging light lights up for a split second but then goes off. Same thing when I put the hand vac into the stick vac body while on the charger. So there is some initial current happening but it's not going beyond that.
I know batteries are problematic on these units, but it's not a case of it gradually losing charge capacity - this was very sudden.
Any help appreciated!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
adrienneiii it is possible that the battery shorted out. When a battery shortens out it just stops vs, running a low charge. That would also explain why "the charging light lights up for a split second" I'd start with that since if nothing else, it will provide you with a known-good starting point for further troubleshooting.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Thanks oldt! Sounds right. Solution - either junk or replace battery, I guess?
por
adrienneiii not quite. Replace battery, if not working try to fix. Don't junk ;-)
por
Thanks, but it's one of those annoying situations where the battery unit costs almost as much as what I originally paid for the whole unit...
por
Hi, I'm having the same problem. Did you ever end up fixing yours?
Calificación 1
Añadir tu respuesta
adrienneiii estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 75
Últimos 30 Días: 329
Todo El Tiempo: 5,163
