Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 1049 Ver todo
My iPhone SE Stuck at 1%.
I replaced the LCD/Digitizer on a broken iPhone SE. I was not able to test it before the repair due to the screen not working. Now the phone reads that the battery is at 1% and it will stay on until the battery drains. I have tried a different battery. Any ideas on what to do next or what the problem might be?
Es esta una buena pregunta?
Puntuación 12
1 comentario
i bought an iphone se 2 weeks ago it was going well and today suddenly i was using it and it was on 51 percent on lowerpowermode i used to put low power mode and suddenly it turned off andturned on showing 1 percent and then it showed again as 21 percent and i just waited for it and i put it to charge and waited and it was 51 percent my iphone was on ios 11.4 so i updated it and still the same i dont know why pls help me and a quick reply
- de
Agregar un comentario
7 Respuestas
Solución Elegida
You could not test it before the new screen and even a new battery made no difference. If the Date/Time suggestion above does not work, it sounds like whatever caused the screen damage also damaged the logic board. You could have caused some Pry Damage or damaged an FPC connector during your repair.
Could you somehow fully charge a battery (in another 5S or SE) and then install it in the device? That would help you understand if the problem is charging related or elsewhere. Charging problems are usually related to a Tristar IC being defective or PRY / FPC damage mentioned above.
This is a difficult repair and unless you have the proper equipment or experience, I would recommend that you find a repair shop that can do micro-soldering repairs.
Fue útil esta respuesta?
Puntuación 8
3 comentarios:
Well idk if there is much you can do but the problem is is that your battery is fried and it needs to be plugged in every time you use it...believe me it happened to me too
- de
I have the same problem, I’ve replaced the screen and then the problem has occurred, however, after reading this comment I hit my phone twice on the wall and guess what! the battery is charging properly. I believe that there is cable is not connected well, If the problem occurred again I will install the screen again
- de
I Would second Minho, yet i would like to add little peace of info.
next the the battery connector on Iphone SE, there is tinny little components(capactiors & filter), one of these component is filter, if you knocked off thats filter during the process of replacing the battery, the phone wont be able to read the battery status which could cause rebooting/charging problems.
Regards
- de
Respuesta Más Útil
Make sure that your iPhone’s data and Wi-Fi are on and connected
Open Settings -> General -> Date & Time
Toggle the switch for Set Automatically Off and On again. The switch will turn gray, then green.
Date & Time - iOS
Restart the iPhone by holding down the Sleep/Wake and Home button until you see the Apple logo
Once your device has restarted you should see the battery icon back to normal. Some users have also said that simply messing around with the date and time can also temporarily fix the error. Simply, toggle Set Automatically ON/OFF multiple times, or switch time zones as well.
Puntuación 11
10 comentarios:
I created an account just to vote yes and tell you that for whatever reason, this fixed my phone so thank you.
- de
oh my gosh thank you so much !! i have been trying to find a solution for this problem for hours !! i too made an account just to thank you. i was freaking out when the toggle alone did not work but then i changed the time zone and then messed with toggle and everything worked perfectly !! i am eternally grateful.
- de
This has not worked for me
- de
This is worked for me as well as others, so thank you so much, I were stack on this more then month
- de
Amazing! How does this work? Well, it worked, and I also created an account to say Thank You :)
- de
Mostrar 5 comentarios más
i had exactly the same issue with iPhone SE screen replacements for a long time (I repair phones for living) and i finally solved the puzzle. This happens due to pry damage. When you try to disconnect the battery connector with a prying tool, i used to nick the capacitor right beside the connector. Check with a microscope, you have to re solder it back on.
Puntuación 2
Well I don't think there is too much you can do but I know the problem...your battery is fried..,now my battery is fried too and I have to plug oh in every time I use it
Puntuación 0
I have the same problem my iPhone6s is at 1% since I replaced the Lcd screen is not charging anymore but before I changed the Lcd screen it was charging fine what must I do now please help
Puntuación 0
I fixed it by letting the phone run all the way down until is shut off, the charging it. Fixed the problem for a month, then it recurred but same fix worked.
Puntuación 0
Actually, this fault is made by technician, there is a capacitor and filter FL2400 is important capacitor is not the problem if you remove it.
So solution is to put back FL2400 taken from donor board or make jumper with 0.02 wire. Iphone show 1% and rebot some time because CPU doesn't know how much power it can consume because this FL carries important battery information. I see this problem many times.
Puntuación 0
Añadir tu respuesta
Michael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 100
Todo El Tiempo: 74,023
