Model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair.
Preguntas 169 Ver todo
My PS4 Controller is dead
My PS4 controller has suddenly died on me. It wont charge and it wont turn on. I replaced the battery but it is still non responsive.
I previously used it with my Xiaomi batter back with a USB type C cable with micro usb extension. I think that caused the problem.
any solution. I basically want to know which part do i need to replace for it to work again
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
It died on me but every time I charge it it vibrates
por
This happened to me. I thought it was the battery and also the Micro usb in put slot problem. I bring it to the support center and they said that the battery is okay and the micro usb slot is okay. It's dead and it's can't be fixed. I used my Samsung Galaxy S7 charger to charge my Dualshock 4 and it happened the next day so Please you guys out there, don't ever us any phone charger that has the out up ( fast charge ) that is higher than what the Dual-shock 4 controller require. It cause the board to burn I think and it won't ever charge again. not even alive while connecting to the USB. It's simply dead and You'll have to get another controller for 60$.
por
Well i was able to fix mine by changing the USB connector board and ribbon. Its easily available for 2 dollars on aliexpress. Just make sure you order the right one as there are 3 variants with different ribbon connectors .
por
this has happened to two of my controllers that will be $200, my other controller is dying for other reasons I was bored so one day i took my controller apart the white cord inside was all f up so I got some more but for some reason, it doesn't connect even though its the same pin cord. sony wants me to pay $200 instead of $14 (it was $14 for the wires.)
I got the controller to work but if i unplug it dies and when its plugged in there's a question mark over the battery
what do i dooooooo
por
Agregar un comentario
4 Respuestas
Respuesta Más Útil
I would double check the battery connection, if that's ok, I would then replace the motherboard. iFixit sells them, I have included the link to the part...
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-011)
Imagen DualShock 4 Controller Motherboard and Midframe Assembly (JDM-011)
Producto
$27.99
Fue útil esta respuesta?
Calificación 1
Comentarios:
If the motherboard cost $38 then why not just buy a new controller
por
your USB port is most likely your problem. you can replace the entire board but the USB port can be fixed with some soldering experience.
Calificación 1
I have exactly the same problem... because my battery was "dead" I decided to put it in charge with my Xiaomi power bank and suddenly my DS4 won't charge anymore !
I disasemble it and I hope it is just just the charging port/board but maybe you(or someone who knows) can confirm me ?
Thanks a lot ;)
Calificación 1
If the DS4 no longer responds with the PS4 then more than likely it's broadcasting a normal Bluetooth signal. To remedy this, I suggest cracking the controller open and replacing the USB board/ribbon cable. And to answer another persons question as to why you'd just buy the motherboard, the motherboard at $38 is actually cheaper than a new controller, which costs about $65-70 each.
Calificación 0
Añadir tu respuesta
Haseeb Qamar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 43
Últimos 7 Días: 226
Últimos 30 Días: 1,034
Todo El Tiempo: 7,540
