A color version of the Nintendo Game Boy, released in 1998. Repair of this device is straightforward.
Preguntas 22 Ver todo
My Game boy game won't load
I'm having trouble with the Gameboy game not loading on my Gameboy Color. it's "Looney tunes "twouble!" ".
this game has gave me trouble in the past but now it won't boot at all whatsoever. now all I get is the Game Boy Color logo and just "®".
I have tested every of your game on your own and it always results with always booting or requiring a bit of coaching to get it booting
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
It may be that 1 of the pins on that connects to the cartridge is bent or something, look inside with a flashlight and see if anything looks amiss
por
I opened it up and it looks completely fine. Also it's only one game that doesn't work out of about 10 that I have
por
I open the game but not the game because I can't open the game cuz I don't have the right stuff
por
I meant Gameboy
por
It may just be that that game has broken... But do the same thing, look at the pis on the game and see if anything is amiss (you don't have to open it) and if everything looks fine the the only way to find out is to open the game up
por
Mostrar 4 comentarios más
Agregar un comentario
2 Respuestas
Solución Elegida
The suggestions by everyone is about as good as you'll get. You'll want to check the pins and give the contacts on the game a good cleaning with rubbing alcohol. If that doesn't fix the situation then one of the chips on the game PCB has probably died. The only way to check a chip (that I'm aware of) is removing it from the PCB and putting it into a tester. Other than that, you would want to inspect the traces on the PCB of the game. run a multimeter from contacts to points on the chip and such. It's a bit of work if you really want find the problem that bad.
Fue útil esta respuesta?
Calificación 2
Comentarios:
I agree with Andrew here
por
Can you give a better description on how to use the multimeter
por
To check traces, you can set your multimeter to continuity mode and touch contacts to either end. A beep or '0' on the screen will tell you there is no disruption on that trace. Checking chips is a rigorous process and extremely difficult without the correct tools.
One of the only other options you could try is reflowing the solder on the PCB using either a hairdryer (for a long time on high) or a heat gun (for short bursts) to heat up the solder and see about reconnecting any problematic spots.
Probably, in this case, a chip has failed, which would require programming to completely repair and at this point its best just to find a new game.
por
Me too. I bought a GBC just a few minutes ago. When I booted up the GBC, it only shows Game Boy logo and the Nintendo® logo!
Calificación 0
Añadir tu respuesta
Jake Donovan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 22
Últimos 7 Días: 159
Últimos 30 Días: 876
Todo El Tiempo: 11,789
