Saltar al contenido principal
Una versión con pantalla a color de la Nintento GameBoy, lanzada en 1998. La reparación de esta consola es sencilla.
Preguntas 74 Ver todo
My Game boy game won't load
I'm having trouble with the Gameboy game not loading on my Gameboy Color. it's "Looney tunes "twouble!" ".
this game has gave me trouble in the past but now it won't boot at all whatsoever. now all I get is the Game Boy Color logo and just "®".
I have tested every of your game on your own and it always results with always booting or requiring a bit of coaching to get it booting
Es esta una buena pregunta?
Puntuación 2
18 comentarios
It may be that 1 of the pins on that connects to the cartridge is bent or something, look inside with a flashlight and see if anything looks amiss
- de
I opened it up and it looks completely fine. Also it's only one game that doesn't work out of about 10 that I have
- de
I open the game but not the game because I can't open the game cuz I don't have the right stuff
- de
I meant Gameboy
- de
It may just be that that game has broken... But do the same thing, look at the pis on the game and see if anything is amiss (you don't have to open it) and if everything looks fine the the only way to find out is to open the game up
- de
Mostrar 13 comentarios más
Agregar un comentario
3 Respuestas
Solución Elegida
The suggestions by everyone is about as good as you'll get. You'll want to check the pins and give the contacts on the game a good cleaning with rubbing alcohol. If that doesn't fix the situation then one of the chips on the game PCB has probably died. The only way to check a chip (that I'm aware of) is removing it from the PCB and putting it into a tester. Other than that, you would want to inspect the traces on the PCB of the game. run a multimeter from contacts to points on the chip and such. It's a bit of work if you really want find the problem that bad.
Fue útil esta respuesta?
Puntuación 4
6 comentarios:
I agree with Andrew here
- de
Can you give a better description on how to use the multimeter
- de
To check traces, you can set your multimeter to continuity mode and touch contacts to either end. A beep or '0' on the screen will tell you there is no disruption on that trace. Checking chips is a rigorous process and extremely difficult without the correct tools.
One of the only other options you could try is reflowing the solder on the PCB using either a hairdryer (for a long time on high) or a heat gun (for short bursts) to heat up the solder and see about reconnecting any problematic spots.
Probably, in this case, a chip has failed, which would require programming to completely repair and at this point its best just to find a new game.
- de
What if you CAN'T find a new game? How would you go about reprogramming it?
- de
Hi Joe, I don't know how possible it would be to reprogram a GBC game chip. I know of some YouTubers that do it with NES games but as for "newer" games, I don't think it's possible. If you're still interested, look around YouTube or Google searches to see if you can reprogram a cart and go from there. Best of luck to you on that.
- de
Mostrar 1 comentario más
Had the same issue of it loading game boy and nintendo but not going past the screen…all i did was blow air into the game and into the back of the game boy and BOOM it turned on YASSSSSSSS!!!!!
Puntuación 0
I don't understand why people are opening up their cartridges and cleaning up the traces, I'm sure that solves the issue, but just blow into the %#*@ cartridge's 😳. It's just like the NES, blow into the game cartridge, try again. Problem solved....
Puntuación 0
Añadir tu respuesta
Jake Donovan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 116
Ultimos 30 días: 545
Todo El Tiempo: 63,753
