The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
Preguntas 1484 Ver todo
iPhone not powering on
After reballing baceband ic my iphone can't turn on. I think that some component must de-aligned near the baseband and also it seems like there isn't C33 component on the board. Is it possible this to cause the problem and if yes where i can get it from?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
@toastedc0re post a couple of pictures of your board and your repiar with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see. Also, how did you reball the IC?
por
@oldturkey03 Added an image. Inform me if you want another one, and thanks for your help!
por
Can you please inform why you reballed it in the first place?
por
@toastedc0re thank you for the image. Any chance you can post one that has a bit less motion artifact? That would make it easier to identify the components
Rep: 31
por
@packinit I tried to reball it with flux and a heatgun as the modem number was blank and imei didn't appear. I had tried before all the "solutions" that i found on the net.
por
Mostrar 14 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
I took some pictures of my 5c connector with an electrical microscope. It seems that there are missing to components. But I'm not sure if mine is complet because I also have some power problems other ones. Maybe these pictures help you.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Thank you for your answer i'll check it out
por
@hehe0903 from your pictures seems like I am also missing components near the battery connector. Seems like the missing components are more than I thought on the first place :/
por
Añadir tu respuesta
georgekarapi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 243
