Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 3932 Ver todo
Poor cell data signal after charging connector changed
I took my iPhone 6 in for a charging port replacement as it was not charging. They replaced the charging dock assembly but when I got it back, the cellular phone and 3G data signal is substantially poorer than before. I do not get signal at all in places I used to get fine signal, and other places I got great signal I get very poor signal. I have lived and worked in the same area for 3 months and had consistent signal every day without change, only now after this repair it is suddenly substantially worse.
I took it back to the shop and explained but they washed their hands of it and said there was no issue.
On the iPhone 4 there were a number of metal tags that connected the cell antennae and if these weren't connected fully it could degrade signal.
What can I check on the iPhone 6 that could be responsible for degraded signal? I do get some signal in some places but it is much worse than before and it is definitely since they replaced the charging dock.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
I had the same problem after doing this repair myself. I then replaced the original part and the signal was fine again. Next I got a replacement part from a different source (not ebay) fitted that, and all is good. So my experience is it was a faulty part. This seems to be a common problem.
por
i have the same problem after installing a new connector from ifixit. I think the new part is faulty, i will try to get ifixit to send me a new one.
por
Agregar un comentario
1 Respuesta
Solución Elegida
First of all, why did they replace charging port?
It is actually quite rare to damage the iPhone lightning port, 80% of the time, it is just dirt, lint, fluff etc. Inside the port that prevents proper charging.
As for signal, it's possible if they replaced it that it may be a low quality part, or they haven't connected everything up correctly.
You could open it up and post some pictures here for me to have a look at, I could possibly help then. :-)
Fue útil esta respuesta?
Calificación 1
Comentarios:
Hey @gedo1992 how familiar are you to replacing the charging port assembly+ on an iphone 6? I just need to know what to avoid to damage the phone, I have successfully replaced the front screen and battery in the same phone so i know a little bit but, this is going to be the hardest repair that i have done. The reason I am repairing the part is, recently my phone was dropped in water but i threw it in a mix of rice and damprid, after about 5 days i tried to plug it in and it ran like a champ again, but when i took the charger out it had corroded so i took a further look and after some thinking and inspection, i found that the damprid had caused damage in the charging port.
por
Añadir tu respuesta
James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 29
Últimos 30 Días: 102
Todo El Tiempo: 2,242
