Saltar al contenido principal
La Acer Iconia Tab W500 es una tableta con Windows 7 que tiene una pantalla táctil de 10 pulgadas y su propia base de teclado.
Preguntas 8 Ver todo
Why wont it boot and some pf the keys wont work
The keyboard gpt wet but i opened it up and sprayedit down with rubbing alcohol and patted it dry as much as possible lightly. It came on and worked fine for a few days then while i was using it one day it just started blinking from one app to another. Like mabe it had a virus. When i finaly got it to go to setting and tryed to do a resset it just went blank it will pull up the acer logo like usual but then just blinks once and goes blank again.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Most likely you'll have to replace your keyboard.
The danger of water lies mostly in dissolving of contacts, snd shorting them between each other. This may be the case, and it is too costly to redo all the wiring.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Christopher Grayham estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 703
