Saltar al contenido principal
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
Preguntas 35 Ver todo
The light on the drone blinks green then turns red
After I had an accident in which my Parrot Bebop fell about 75 feet, I could not turn the drone on again. When I pressed the rear light to start the drone, first the light blinked green and then turned red.
I at first thought the problem was one motor that had been damaged. I replaced the motor in question, but the light still blinked green and turned red.
Eventually, I took the drone removing the motors, camera, and gps until there was only the motherboard connected to the battery. Now, I still get the same response. When I press the turn on button the light blinks green and then turns red.
Do you have any suggestions for repairing this Parrot Bebop?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
Have you found a solution? I have the same problem and am unable to find a cure anywhere.
- de
Agregar un comentario
2 Respuestas
This has to do with either
Disconnected motor
Or disconnected GPS board
Fue útil esta respuesta?
Puntuación 0
i am working on mine right now and it seems that the motor drivers have an open ground or negative, when powering on the motors should activate a few short pulses. my drone does not, but you know guys it would be a !&&* of a lot easier if they would supply a circuit diagram
Puntuación 0
1 comentario:
Okay, so I took the drone completely apart and searched for any connections that might be questionable. I did not find any obvious issues, just for being able to say that I did something I reflowed the power connections to the mainboard and reassembled the drone. It is working again. Very nice construction of the mainboard. I would say, it's probably 5 layers thick.
- de
Añadir tu respuesta
cmitc estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 2,912
