Back light dark on top
Dark the top is black
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
@duba is it just darker or is it black? do you still see things on that part of the screen?
por
I have the same problem, my screen is dark in the top.
por
I have a similar problem but I have no image or sound it just blinks now on and off and the top of the tv is darker then the bottom I replaced the power board and the main board and still no fix need any tips!
por
I have the same problem. it started gradually getting worse now to the point the top is virtually un-viewable with the darkest at the top fading back to normal at the bottom. there is three cards in the back, has to be one of them i would think.
por
@georgesl not necessarily. Could be the LED strip that makes up your backlight. Repairable by disassembling the panel itself and hopefully getting an LED replacement
por
Agregar un comentario
1 Respuesta
Solución Elegida
@dube @lintaum this is most likely caused by a failed backlight. Could be the power board, the LCD or the inverter circuitry. This is a vague answer due to the fact that we do not have all the information.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Portia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 17
Últimos 30 Días: 71
Todo El Tiempo: 1,158
