Why factory reset is disabled by server policy?
Is it possible to do a factory data reset under this policy?
Es esta una buena pregunta?
Mine did this, and my antivirus had root/reset blocked. Simply punched my 6 digit antivirus code into my antivirus app, and then set the setting to not block root/reset. Fixed---just like that.
Fue útil esta respuesta?
Thank you! My McAfee was blocking my Sim from being formatted. Went under McAfee settings and clicked to turn off the block, entered my 6 digit pin and viola! Sim now working! I even contacted my phone's support and all they suggested was for me to just remove the Sim. So I'm glad I came across your comment! Thanks again!
Yes, it is possible, but only by doing a hard reset. Instructions from the LG site for this are as follows. As with a regular factory reset, you will lose all data on the phone!
Using the hard reset
If you cannot recall your unlock pattern, PIN, or password, you need to perform a hard reset to access your phone.
When the phone is turned off, press and hold the Home Key + Volume Down Key +Power/Lock Key . When the screen shows the LG logo, release thePower/Lock Key .
When the screen displays an Android robot animation, release the other keys.
Leave your phone for at least a minute while it performs the hard reset, then your phone will reboot.
I did that it sent me to safe mode
Can someone tell me.. what's wrong with my device
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 7,440
2 comentarios
I disabled a required setting so I can't text when I open my contacts it doesn't allow me to send a text because it says that I disabled a required setting how do I enable that setting back so I can text from my display of contacts
- de Dean Nieto
Dean, please remove this as a comment and post a new question. Otherwise, your question likely won't be answered.
- de S W
