Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
After replacing cracked screen phone will not power on.
I replaced the screen and digitizer on an iphone 6 and now it will not power on. I tried to put a new battery in it but still will not power on. All connections are good and no internal damage. The phone was working prior to my replacing the screen. I tried 3 different brand new screens.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario:
When u connect to iTunes it recognize your iPhone?
- de
Agregar un comentario
1 Respuesta
If the phone is recognized by itunes but doesn't appear to be booting up, it is possible that the phone is booting but has no display or no backlight because the traces on the board below where the screws go to hold the plate over the LCD connectors. If you mix those up and stick the 1.7mm screw in the hole that a 1.3mm screw belongs in you do what's been appropriately named "long screwed" your phone. google long screw damage iphone 6.
If the phone is not booting at all, I still suspect the board is damaged somewhere. Repairing a logic board is beyond most DIY repair-ers
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
OmahaWest estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 57
