Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
New iFixit battery installed, pressure on screen now
I just installed the ifixit iPhone 5s battery replacement with adhesive and now have an LCD rainbow along the center line. It shows up when pressing the home button and when tapping the lower half. The screen does not experience this effect when the LCD was removed and held away from the phone body with the connectors attached and powered on. I removed all the old adhesive. I attached the new adhesive. I went as far as pealing off the ifixit label on the battery and it helped just a little.
Update (04/30/2016)
The battery didn't change dimensions from when new, but after sitting overnight in the phone, the screen issues are a little better. Yesterday, it would rainbow on taping on the lower half, but today it rainbows on a direct hit. The battery install is one shot. If I were to remove the battery and reinstall, I'd need another battery because I'm sure I'd bend it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Have you tried pushing the battery down lower? Can you take a photo of the battery? Is the battery adhesive like the same as the previous one?
- de
Does the battery appear swollen at all?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I put to much focus on the new part going in my phone and not enough on the old parts going back. The metal bar over the battery connector became flipped. It has been reversed an all is fine now.
Fue útil esta respuesta?
Puntuación 1
Since your order was recent, go ahead and call or email iFixit. They will gladly send you out a new one. It appears your battery is swelling and that is no bueno :(
Puntuación 0
Añadir tu respuesta
wolear estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 124
