Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
iPhone 6 screen unresponsive
Ok so I had a customer bring me a phone that has been to several other shops and they recommended coming to see me. The phone has the original screen on it and just randomly stop responding to touch. IF you do the soft reset (power + home button) it will work for about 10-30 minutes and freeze again. The other repair shops called me and let me know they tried multiple screens and it still froze up. Ive tried several with the same results. Anyone know what could be causing this issue? All connectors look perfect and all the resistors that control the touch seem to look ok. My only guess would be the touch IC chip....would this be a correct assumption?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Replace both Touch IC's . i think that will sort the problem. i had similar with mine.
Fue útil esta respuesta?
Puntuación 0
I would guess it is the touch ic as well.
http://www.mendonipadrehab.com/entries/g...
Puntuación 0
1 comentario:
thats what I figured it was, Ive replaced them before on the iPhone 6 Plus that gets the static bar at the top and it corrected this issue on them as well.
- de
Añadir tu respuesta
chad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 432
