Saltar al contenido principal
El Toshiba Satellite Click 2 Pro es un portátil híbrido de 13 pulgadas sencillo y fácil de usar, creado por Toshiba en 2014
Preguntas 14 Ver todo
My computer is overheating a lot and I don’t know why
I have been using my laptop a lot lately and I noticed that it is getting really hot on my lap. It will occasionally shut down if it gets too hot. Is there any quick fixes to the issue?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Hi guys , since last 10-15 days . in my laptop while i play some videos or movie it plays like scratching videos as well laptop is being slow too . i checked @ CPU meter app , it shows RAM on max uses and cpu is like normal , plzz hlp some idea . RAM meter is locate always above 48 is it normal or anythings else
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The laptop is overheating because of the surface that is being used upon. Depending upon the area it is being used can cause numerous issues. The main problem the computer can encounter is the overheating problem. This is a result of the air filter not receiving the optimal amount of airflow necessary for the device to run at optimal conditions. The simplest solution is to use the laptop on a smooth area with nothing that can hinder the airflow.
Another reason the laptop can encounter this problem is the CPU is being strained because of the amount items being run simultaneously. To fix this issue try opening the the task manger, right click on the windows icon -> select task manager-> Check CPU -> Close Unnecessary programs .
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Paul DeOrsey estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 311
