Saltar al contenido principal
Teardown images for axentwear cat ear headphones
Dose anyone have any images of teardown of these headphones to do some repairs. Alot of people have had defects with their pair. From the LEDs stop working, low sound coming from the left or right channel of the ear cup speakers, or distorted sound from the cat ear speakers. I bet any help would be better then what is currently out there from a Google search. As I have looked without and real definitive way to fix the problems.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
7 comentarios
For me it was one side completely stopped working.
- de
The left side of my headphones the twistable part popped out and broke,now i cant fix it
- de
same here... im looking for replacement parts rn.... im surprised we have the same problem
- de
Wow. That same part of mine is fixing to pop right out... I just want to know how to fix that... it's my favourite headset after all.
- de
Does anyone have a broken axent headset they wanna sell? I need spare parts :P
email: ompersen@hotmail.com
- de
Mostrar 2 comentarios más
Agregar un comentario
4 Respuestas
Respuesta Más Útil
I found a tear down http://www.etotheipiplusone.net/?p=3872, I've got some issues with the new pair they sent me, so I'll try the dissemble tonight.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Did you ever find a part source? I have proven a speaker is bad buy swapping left and right but i can't source a replacement.
- de
My pair was having an issue where all the lights EXCEPT the right ear cup were flickering like there was a short. I took the headband off and the issue stopped. Not sure what I could have done to accident into a fix.
- de
This may be a viable solution: http://www.petitionbuzz.com/petitions/fu...
Puntuación 2
1 comentario:
As it is one way to go on it. I have signed up months ago on it. And from the looks of things it has been sitting in limbo.
- de
For the cat ear LED problems, just gently press down a few times on the headband cushion until you feel the surface that's there, which is the ribbon cord, on the side according to which cat ear LED is malfunctioning, and that should fix it, the ribbon cord is exposed under the cushion which is why it probably causes LED problems but at least it's an easy fix due to that
Warning: The ribbon cord is somewhat quite fragile so make sure you’re doing it gently to avoid damaging it, it doesn't need much pressure to fix it
Puntuación 2
1 comentario:
This has fixed an issue I have had for years that I ignored trying to fix till I was watching a random JayzTwoCent video and reminded me to look up a possible tear down on here :) thank you for the LED easy fix option :D
- de
I'm not sure if this post will do any good at this point, but my headphones had the problem with the LED lights not working only...specifically on the left-hand side where the jacks are and the ears on top. What I did was unscrew the right-hand side of the headphones and jiggle the wire in the top left (pictured below) and then wrapped it up with electrical tape. I kept the LEDs on while working in order to test whether or not this was the problem and it did the trick. They are fully functional again as if I bought them yesterday. I used this Youtube Vid below to help take apart the headphones as well. I hope this helps someone out because this problem frustrated me for years.
https://www.youtube.com/watch?v=ddfLnvwr...
Puntuación 0
Añadir tu respuesta
anigames estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 9,001
