Why the battery is not charging up?
my phone is not charging while it is plugged in ? if you plug your phone in the adopter and it is not charging or it charges but does not full up the battery.
Es esta una buena pregunta?
if the light of the charging is on while the device is plugged in but still not working then the try to replace the charger and plug it again and see.
in case you replace the charger but the still device is not charging up then the chance is it might be the battery therefore replace the battery immediately.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 624
