Samsung galaxy tab 2 10.1 Boot Loop
I know how to fix a boot loop, but not this on. So I have got a boot loop in my tab. I tried ASR, updates and clearing my data. Nothing. Is there anything else I can do?
Es esta una buena pregunta?
Hi,
Have you tried disconnecting the battery, holding the power button for 30 seconds to dissipate any residual power in the tablet, then reconnecting the battery and seeing if it starts normally.
Here is a link that shows how to replace the battery. It is useful as it shows how to open the tablet. It also shows the battery connector (with the red and blue wires) and how to remove it from the socket at 5:00 minutes into the video. The battery connector seems to be able to be accessed quite easily and as you are not replacing the battery, it should be able to be disconnected/reconnected without having to remove other cables, components or screws, except for a piece of tape, shown starting to be removed at 2:43 minutes into the video.
Fue útil esta respuesta?
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 25
Todo El Tiempo: 2,744
