Saltar al contenido principal
How to disassemble my iHome?
I had an issue with my power dock, and I need help disassembling this. I unscrew all five screws from the bottom, but with as much force as I can use, I still can't pry the bottom part from the top. Any help?
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
2 Respuestas
Solución Elegida
Hi, Just wondering if there are any more screws in the battery compartment or under the 'feet'.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Well, I'm an idiot. Thank you so much xD
- de
Hi, Don't be so hard on yourself. We've all been there and no doubt be there again in the future. At least you thought to stop and ask.
- de
I had the same problem, Since the rubber feet were so close to the screws, i though they would not put another screw, so close by, under the rubber feet. But they did - the 2 feet on the clock face side. The other 2, do not remove the rubber feet because you will weaken the adhesive, and there are no screws.
Puntuación 1
1 comentario:
On my unit the dock mount broke. I opened up the unit and ran the dock connection to the outside of the case since the mount was not fixable. Not as nice, but it works.
- de
Añadir tu respuesta
Lance J estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,809
