Error Code UE on Kenmore Elite Washer
What does error code UE mean? And how do I fix it?
Es esta una buena pregunta?
Load is unbalanced or too small
Fue útil esta respuesta?
This was my issue and sitting on the drying fixed it!
My washer is trash. I’ll never buy kenmore again. I can’t wash my clothes without it taking two hours because it says UE every 10 mins. Think is &&^&^$ junk. It’s a nice washer too but I’m over it. Scrapping that pile. Thing has caused me so much stress
I have the same washer and it’s complete TRASH I’ve never had so much stress takes hours to do laundry bc always getting UE WORTHLESS WOTTHLESSS ILL KICK THE JUNK PILE
If you are continually getting the UE and or you get the error running a empty basket on spin, this being on the top load Kenmore Elite washers , it can be the "hall" sensor on the stator. Recommend replacing the stator "motor" which usually comes with a new "hall" sensor attached. This solved problem for my customer.
This was the second time this has happened and I've had it less than 5 years. And Sears Service SUCKS!!! I will never buy a Sears machine again. I just need help in finding the right part for my machine.
This washer sucks dick I’ll never buy Kenmore again. I do express wash and it takes me 2 hours to finish my clothes because it stops and says UE. Washer is trash. Never again I’m scrapping this pile of junk
I just replaced the hall sensor on mine but it did not fix the issue. Next step is replacing the suspension.
If you push down on center of basket "empty" and it comes back up without bouncing, (stiff), suspension is good, if it is real weak , it'll bounce up and down a few times. ( like bad shocks on a car). Could also be bad gearcase. If in spin it sounds really loud, ( like a jet airplane), gearcase needs replaced.
Who the &&^& wants to change sensors and motors on the *!&*^#% washing machine!!!! This pos won't even spin! Where is the &&^&^$^ knobs and the spin setting? I'm stuck with wet clothes and a stupid machine because some dumbass was trying to get fancy with a simple &&^&^$^ washing machine that worked fine with knobs!!!
All you have to do to spin only is turn it on (don’t spin the dial to select the wash cycle) and hit the spin speed select button ( choosing the spin speed) and hit the start button.
Meant to put GE, not HE.
Find a cheap old washer. New machines stink. GE top load washers are the worse.
Most issues are shock related on new top load washers. Push down on center basket and let go.. see if it bounces another of issues are because it bounces around etc. The Kenmore washers have crappy gear cases with a lot of plastic pieces. Some have a plastic cover to keep things from hitting the belt. They collect crop into them or rub floor if on carpet ..
Get AN OLD WASHER OFF CRAIGSLIST OR FACEBOOK!
If you're having this issue for LG front loader turn off the machine, take your cloths out of the drum. Leave the drum completely empty, turn your water on, and press on Rinse and spin cycle, then press start, it should be complete in 20mins. When the cycle is done, wait for 5 mins, then continue your wash. Enjoy
Ultimas 24 horas: 2
Ultimos 7 días: 33
Ultimos 30 días: 143
Todo El Tiempo: 25,853
