How can I fix this
I dropped my iPhone5s earlier, and now it has a straight big black line on the left side, and won't stop glitching and works then doesn't, someone please help me. Suggest things I can do?
Es esta una buena pregunta?
Chloe,
Looks like the drop fractured the LCD or damaged the solders on the back of the LCD. A screen replacement will fix it.
Regards
Holger
Fue útil esta respuesta?
I agree with Chloe that a new screen will most likely fix your problem.
If a new screen does not fix the glitching then that will tell you that the logic board has an issue.
Sometimes after a hard drop a cold solder joint can form behind the Touch IC which would cause glitching like you describe.
Good luck.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 61
1 comentario
Glass cracked or not cracked? Also is the frame bent?
- de Ben
