Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
"Software for this iPhone is currently unavailable" error message?
I bought an apparently water damaged iPhone 6 - but found the water indicators were still white?
Anyway, I plugged it in and it all recongised the device, except it said it's in recovery mode. I tried to restore it and it says:
"Software for this iPhone is not currently available. Make sure you have the latest version of iTunes and try again"
I have the latest version of iTunes. I've tried a new screen and battery - any ideas what else I can try to fix it?
Thank you :)
Es esta una buena pregunta?
Puntuación 4
5 comentarios
did you try putting it in a bowl of rice?
- de
Did you try to put the device in DFU mode over the first recovery mode ? Maybe try to restore the software on another computer like a Macbook on OS X El Capitan to be sure to have the latest iTunes version available!
- de
software for this iphone is not currently available restore iphone
- de
Download 12.5.1. You will have to google the download. Apple is a POS and every download they offer on the site is only 12.1. I downloaded 12.5.1 from a 3rd party and it worked
- de
A big thanks to you "The IT Nutshell" Downloaded 12.5.1 & it worked for me on windows 64 bit platform
- de
Agregar un comentario
2 Respuestas
Solución Elegida
What version of itunes are you running and what operating system? Ben is correct with the suggestions and answer he provided but I have read that the operating system for Windows XP and Vista will not update to the latest version of itunes. "If" that is the case, then try using another computer with a more recent operating system and make sure itunes is updated on it before attempting an update/restore on it.
Also, pay attention to error numbers itunes may provide (if any) and repost results. Best of luck!
Fue útil esta respuesta?
Puntuación 1
1 comentario:
- de
Respuesta Más Útil
The issue could be anywhere on the board. Unfortunately the only option is to send it to a professional to remove the EMF shields and inspect the device under a microscope to see exactly where the issues is. As far as a know though, with the iPhone 6 specifically, most (including myself) will only offer a data recovery service after water damage due to the nature of water damage and the fact that it can be progressive.
For example right now you are stuck in recovery, tomorrow or next week you might loose backlight, and already or down the track things like the camera, reception, touch screen, ect may not be working. The reality is there was almost definitely "other" issues with the device, someone tried to restore it thinking it would fix the corrosion somehow, it didn't, the device got stuck in recovery, and so they sold it.
Who knows what did or didn't work prior to the device getting stuck in recovery, but based on your specific description of the error it sounds like the Baseband CPU is not responding, (which could be an issue at the BB CPU itself or the BB PMIC aka PM8019) and so itunes can't accurately determine exactly what device it is dealing with (although it probably still knows its a iPhone 6)
Also worth mentioning the water damage sensors don't always go red, so if they aren't, it just means they specifically didn't get wet. What water got on the underside of the board/shields is an unknown variable until someone checks it out though.
The water itself isn't the issue, its the impurities in the water that make it conductive/corrosive. Basically drying it out at this point, no matter how much rice you use, will do nothing at all. The impurities from the water have made it somewhere important, and have already caused damage. There's a very high chance solder underneath BGA IC's will need to be replaced, at the least :(
Puntuación 2
1 comentario:
- de
Añadir tu respuesta
John Taylor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 35,521
