My Toshiba laptop is making a loud whirring noise. What causes this!
It's made the noise before but usually gets better and quiets down. Is it the fan? Doesit need cleaning? If so, how do I clean it?
Es esta una buena pregunta?
Hi,
its probably clogged fan so cleaning would be the best option
take a look at this youtube video (credits to the author): https://www.youtube.com/watch?v=f-9DTj8a...
it might help :)
Regards,
Kris
Fue útil esta respuesta?
don't stop there Kris explain how to clean the fan
updated with video guide :)
I was having that problem also. I have a Toshiba Satelite that’s a few years old. After taking the back off (there are screws hidden beneath the pads closest to the hinge) I figured out that although the fan was clean it would sometimes hit against the fan housing when it spun at certain speeds. Instead of a gentle whir it was really loud. I fixed it by repositioning a silver pad that was stuck to the case a couple of inches from the fan so that was centered over the fan. The slight pressure between the fan and the case seems to keep the fan from hitting the housing.
جهازي كان يصدر صوت طنين عالي وبعدها اعمله اعاده تشغيل ويذهب الصوت
الان لم يعمل الجهاز شاشه سوداء لكن اضواء الواي فاي والبطاريه تعمل كيف يتم اصلاحه
Google Translation
My device was making a loud buzzing sound and then I restarted it and the sound went away Now the device does not work, black screen, but the Wi-Fi lights and the battery are working, how to fix it
Shams Alali what device is this? What have you checked?
Fujitsu sprmobil v5666
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 16,316
