A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
Preguntas 26 Ver todo
Why can't I connect my device to a wireless network?
I can't connect my device to a wireless network.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
  • If you are having issues connecting your device to a wireless network, your device may have been operating continuously for too long, and you will have to restart the device. Restart the device by holding down the power button and selecting to turn off. If you do not see the option to turn your device off on your screen, hold down the power button on your tablet for 40 seconds until it turns off, then start it up again.
  • If rebooting the device doesn't solve your problem, your tablet may be running outdated system software. Instructions on how to update your device software can be found here.
  • If you are still having issues, your WiFi connection may be the problem. When attempting to fix your WiFi network you should take these several steps (no particular order is required) :
  1. Power cycling your wireless router. Instructions can be found here.
  2. Changing the type of security on your router from WEP to WPA2.
  3. Changing the setting on your router to disable 802.11n and limit it to 802.11g.
  4. Finally, Changing the settings on your fire tablet to limit its wireless speed to 54Mb/second.
  • Additional help on this issue can be found here.
  • For more information regarding troubleshooting your Amazon Fire 5th Generation, click here.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Hootan Adibfar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 9
Todo El Tiempo: 279
