Repair guides and support information for EVGA tablets.
Preguntas 889 Ver todo
The charge port pin is bent or broken on an RCA tablet
The pin in the charger port is either bent or broken off and RCA Tablet model RCT6103W46 will not charge.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Cannot find a video that shows how to open your particular model (RCA Tablet model RCT6103W46) but here is one for a RCT 6203W46 which may be close enough to be helpful in getting yours open.
https://www.youtube.com/watch?v=V-bFHycv...
Once open you should have access to the charging port connector and can see what board connection type and configuration it is so that you can find a replacement part. You will probably need soldering skills and tools to remove / replace the connector.
Hopefully this is of some help.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
robertslisa1 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 27
Últimos 30 Días: 147
Todo El Tiempo: 2,417
