Screen lines stripe when temperature is cold?
hello everybody !!!
my problem is when my AC is on and the temperature is colder my A1502 screen has horizontal lines , i am obliged to open all my applications to make the processor warm and afterward it's okay , i would like to know how to fix it? please
Update (02/29/2016)
Yeah solve the problem at 50% I see the display line screen problem happen when my system is cold I use an app : TG PRO to boost my fan and after 2-3 mins, everything is good and I can use my mac, or I open the app required a lot RAM & processor load after I can use it!!! If someone have a better solution let me known :)
This video gonna help you fix It https://youtu.be/12dVmqLn644
You have to install the Program and go to Fan>Manual>slide it to Right to warm you computer. and he gonna be stop flickering
Es esta una buena pregunta?
3 comentarios
Is there another solution for that problem meanwhile? I have the exact same issue with my 13” Retina MacBook Pro from Mid 2014. When it’s cold on startup the screen is flickering. After a few minutes it stops.
I mean, is there any solution, to stop that flickering on startup, even when its cold? Except for replacing the display for 350-400€?
- de Lukas Altmeier
I have this exact same problem with the exact same model. Did you ever find a solution? I am considering replacing the LCD, but don't want to do it quite yet. Please let me know if you solved it.
- de lalazart
The same problem. Please write back if you've solved this/
- de mattday92
