Saltar al contenido principal
Esta cámara instantánea de Fujifilm ahora cuenta con un cuerpo más delgado y liviano que las revisiones anteriores. El Mini 8 ayuda al fotógrafo alertándoles sobre la apertura recomendada. También tiene un modo de flash High-Key que ayuda al fotógrafo a obtener retratos suaves para una apariencia deslumbrante.
Preguntas 355 Ver todo
Camera won't switch to different lighting settings
I brought my instax mini eight out for the first time to take a couple pictures on a hike, and when I went to adjust the lighting from indoor to cloudy, it didn't change. The orange light switched between all of the settings without me turning the dial, and eventually became stuck on the indoor setting. Can the camera be fixed?
Es esta una buena pregunta?
Puntuación 7
5 comentarios
umm what if the lighting setting/the adjustment for the lights does not flash
- de
My film wont came out and the censor light wont turn down even when i shut the camera down, how can i fixed it ? :(
- de
my light doesnt change to any of the icons it just stays on "home" icon, I JUST GOT IT OUT OF THE BOX
- de
My problem is that, all of the icons are all lighted? How can I fix this? Please I badly need help. Thank you
- de
I had the same problem! It may be just a mechanical problem but if you look closely at the lense, you will see that it still opens and closes with each dial turned. The orange light is just showing what its on but with that broken, the whole thing still works. The lense with the biggest opening brings the most sunlight and the smallest opening is the darkest setting. Hope this helped!
- de
Agregar un comentario
8 Respuestas
Solución Elegida
I don't think the camera is broken to begin with.
The orange light next to the exposure dial suggests the correct setting of the dial, it isn't supposed to change when you turn the dial. You just have to turn the dial so it matches the light.
The correct procedure is to point the camera in the direction of the subject, then turn the dial to match the light. Also, on the front of the camera next to the flash window there are two small round holes, be careful not to cover these with your fingers when you hold the camera: these are the light sensors, and they cannot work correctly when they're covered.
Fue útil esta respuesta?
Puntuación 18
6 comentarios:
Its causing my photo quality to be bad or faded because its so sunny where I am at.
- de
Thx so much It really helps me bc I thought mine was broken this lets me know that some people are also having this problem that can be solved
- de
What if the light on the dial won't turn on
- de
thank you so much, It never did that before so I thought it was broken.
- de
I tried it in a really dark place and then outside when it was sunny, and the light dial still the same. This causes my photos to go dark, is annoying.
- de
Mostrar 1 comentario más
thank u!!! this really helped
Puntuación 2
thank you so much!!!!!!!!!! I thought my camera wass broken bc it wouldn't switch light positions, but now i know it is fine.
Puntuación 1
1 comentario:
but i had this since last christmas, it was like thaat as soon as i opened it, and even in the sun it does not change dials or settings...
- de
Thank you so much!!!! This really helped
Puntuación 0
Omg this makes so much more sense thank you so much.
Puntuación 0
I put my new film in the instax mini 9 but the S is not changing to 10 and it is not taking pictures.
Puntuación 0
Wow! Thanks, it makes TOTAL sense. I was already thinking the camera was broken!
Puntuación 0
Oh wow I was having the same problem with my instax mini 9 and also though it was broken Thanks.
Puntuación 0
Añadir tu respuesta
Kelly Giordano estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 115
Ultimos 30 días: 525
Todo El Tiempo: 133,518
