Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1131 Ver todo
What caused my screen to dim
I dropped my phone today. Has a screen protector and case so physically there was no damage but now the top right corner is dim. Otherwise still works perfectly. Thoughts? Is it an easy fix?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
2 Respuestas
Solución Elegida
Not real easy , kinda sounds like you damaged the LCD . Is the touch function working in this corner of the screen ?
Fue útil esta respuesta?
Calificación 1
Comentarios:
Yes the touch functions have not been affected. Just dim
por
If its dim in just one corner of the screen then you've likely damaged the LCD
por
You have damaged the LCD, change the screen and this will fix the problem.
Calificación 0
Añadir tu respuesta
postmanrp estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 114
