Use these guides to repair phones from all manufacturers and service providers.
Preguntas 48826 Ver todo
Is there any replacement for the battery for this model.
is there any replacement for the battery for the oplus xonphone 5 model? I had purchased this from snapdeal. now out of warranty after 1 year. but the cust care numbers are not working. hence BL-5404 is the battery make.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
i have oplus xon phone 5 mobile, but its battery is not working . is it replaceable. if yes .plz inform me
por
it probably not has the replaceable battery yet.
por
I want to oplus xinephone 5 battery
por
Agregar un comentario
6 Respuestas
Respuesta Más Útil
Hi,
For Oplus Xonphone 5, I used the Intex BR2075AD for Intex Aqua I7 With 2000mAh. The specifications are the same and fits nearly well. Only, you may have to add support at the bottom of the battery as the height is lower (shop guys fixed this with a plastic wire).
It is working well and I have switched back to the phone from the standby I was using.
Regards,
vpreddy
Fue útil esta respuesta?
Calificación 2
Comentarios:
It really works
por
Are u like 100% sure it works cuz i dont wana order it n then see tht it dsnt fit i dont mind adjusting anytg but wen i checked the battery which u refered it looked a bit smaller compared to my oplus xenphone5:( please can anyone confirm it works n let me know asap...will appreciate ur kindness:)
por
Ya Sarah it works, thanks to VP Reddy for sharing the details, just the size of battery is slightly short from side and bottom, but it can be easily fixed with some packing of hard cardboard piece by yourself.
por
Alright thanks alot santosh:)
por
Guys, I had the same problem. Found Spice Model-SCRB-16 a perfect fit. No adjustments required. However one glitch is that after just 7-8 months I am needing a new battery. (I have doubt the shop sold me a duplicate). But if you buy an original spice battery may be it would last longer.
por
Like I mentioned earlier, Spice SCRB-16 is a perfect fit. However its longevity depends on the genuinity of the battery.
Calificación 1
Comentarios:
Could your please tell me the spice mobile model number using this battery and where can I get this battery. I tried service centres of Spice. they dont have it.
por
Hi,
For Oplus Xonphone 5, I used the for Micromax A67 With 1800 mAh. The specifications are the same and fits nearly well. Only, you may have to add support at the bottom of the battery as the height is lower (shop guys fixed this with a plastic wire).
Regards,
Senthilmurugan. R
por
'model: SCRB-16 Spice mi 508
por
Intex BR2075AD for Intex Aqua I7 With 2000mAh use thins one fix your problem
Calificación 0
ebay is selling these intex aqua i7 battery. Any one bought it From online Is it working nice.
suggest me to buy it.
http://www.ebay.in/itm/152120698675?aff_...
Calificación 0
Calificación 0
please share the online links from where a replacement battery for xonphone5 can be purchased...
Calificación 0
Añadir tu respuesta
svsprasad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 17
Últimos 30 Días: 59
Todo El Tiempo: 6,076
