Saltar al contenido principal
Esta Nintendo DS Lite se lanzó en 2006 como sucesora de la Nintendo DS. Entrar dentro de este dispositivo es simple, lo que facilita las soluciones.
Preguntas 314 Ver todo
Nintendo DS Lite Will not turn on
So about a month after I got a Nintendo DS Lite motherboard and installed it, It would not turn on or charge. When I plug it in, the charge light turns on for about a second and then turns off, and when I push the power switch up, Nothing happens whatsoever. Both fuses are good(0 ohms), and L2 reads fine, there is continuity between the power switch and pin 12 (PWSW) of the power management IC. I have another DS Lite motherboard that will charge but will not turn on (both fuses good), and the game card slot is taken off. So I have a parts motherboard if I need it. Help will be greatly appreciated because I really need to do my daily Brain Age.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
3 comentarios:
Do you have a spare battery that you can test the DS Lite with?
- de
Yes I do, still does not work. It is supposed to turn on even with no battery when plugged into charger. (and yes the charger is good.)
- de
I am sorry, I have the same problem with mine, too. If I find out how to fix it, you will be the first person I tell.
- de
Agregar un comentario
1 Respuesta
If you're absolutely positive you're F1 & F2 fuses are good, double check the soldering job on the charge port. There may be only 1 pin connected or it's lifted somehow. Beyond that, keep testing with a known good working battery. Generally, I've found, that if there is no green power light coming on, it's either the battery, charge port, F1 or F2 fuse.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
What if my orange charge light comes on when I plug it in but as soon as u try to turn it on the green powered on light stays on for 1 second and the bottom screen stays blackwhile the to screen flashes from solid black to white just once the powers off and still is indicating that its still charging
- de
Añadir tu respuesta
Nathaniel Clark estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,240
