Saltar al contenido principal
La PlayStation 3 (o comúnmente conocida como la PS3) es la tercera consola de televisión producida por Sony Computer Entertainment, esta es la sucesora de la PlayStation 2. Fue lanzada un 11 de Noviembre de 2006.
Preguntas 781 Ver todo
My PS3's HDMI port isn't working
My PS3's HDMI port stopped working and I had to switch to the Component cables. It was working perfectly and one day it just stopped. The TV seems to be getting a blank signal since it doesn't say no signal. I've also tried switching the HDMI to another port on the TV
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Did broke the connector of the hdmi jack when you plug in the hdmi cable to the port?
it easy to break it since this is soldered on the motherboard like a power jack on the laptop motherboard.
- de
Well i had the same problem and im still trying to fix mine to also i just tried everything :/
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Did you check with another HDMI cable? That would be my next move if I were you.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
If it turns out that the cable is not the problem, you can try resetting your video card. Hold down the power button for about 15 seconds. It will turn on and then back off again, with a couple of beeps.
Puntuación 1
1 comentario:
I did this to get it to switch to component
- de
I have had my USB and HdMI ports serviced at a repair company called VideoGame911. They did it really fast. I had it back in less then a week.
Puntuación 0
Añadir tu respuesta
Jorge Fernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 17
Ultimos 30 días: 45
Todo El Tiempo: 19,357
